what coilovers should i use ?
Old 09-20-11, 05:01 PM
jc11
jc11's Avatar
Default what coilovers should i use ?
what coilovers should i use im not in to racing i only drive my gs300 on the weekends . i was thinking on using springs for a 2" drop . I dont like the gap wheen i put my 20s on so this time i want to make it right this is my 4th set of wheels and i think this are the ones. im thinking on using the . MEGAN RACING - EZ STREET COILOVER (MR-CDK-LG98-EZ) $699
Spring Rates: 10kg/mm Front and 8kg/mm Rear
- 15 Levels of Adjustable Damper Strength
- Aluminum Brackets paired with rubber inserts
- Rubber Dust Covers
- Adjustable Ride Height
- Conservative Spring Rates
- Single-Cylinder Design - mono-tube
or the MEGAN RACING - LP STREET COILOVER (MR-CDK-LG98) $899
- Features:
SPRING RATES:
F: 62mm ID; 200mm length; 10 kg/mm
R: 62mm ID; 200mm length; 8 kg/mm
DAMPER SPECS:
F: 115mm stroke; 250mm length; A2 valving code
R: 135mm stroke; 260mm length; A1 valving code
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Aggressive Spring Rates
- Aluminum Brackets
32 Levels of Adjustment:
any ideas on what to use
Attached Thumbnails what coilovers should i use ?-coilovers1.jpg   what coilovers should i use ?-coilovers2.jpg
Old 09-20-11, 05:07 PM
SoCal Cyco
SoCal Cyco's Avatar
search, it is up to you what to use
Old 09-20-11, 07:55 PM
jc11
jc11's Avatar
Thanks. I been reading the only question i have What's the big difference between the 2 right now I'm thinking on going with the blue ones
Old 09-20-11, 08:42 PM
1lexus2c
1lexus2c's Avatar
I'll go with bc extreme coilover ...
Old 09-20-11, 10:12 PM
SoloKaMGS
SoloKaMGS's Avatar
Megan Luxury in my book hands down !
Old 09-20-11, 11:36 PM
SoCal Cyco
SoCal Cyco's Avatar
so would i, it just alittle bit more $$
Old 09-21-11, 06:02 AM
4eign
4eign's Avatar
+2. Am very happy with them (i was considering Tein CS).
Old 09-21-11, 09:11 AM
scriber
scriber's Avatar
Megan LP's
Old 09-21-11, 10:35 AM
sakataj
sakataj's Avatar
Originally Posted by scriber
Megan LP's
thats what i have, no issues with them
Old 09-21-11, 12:16 PM
Lexustrung
Lexustrung's Avatar
bc racing coilovers
Old 09-21-11, 02:44 PM
OT0814
OT0814's Avatar
I have BC racing but if i had to choose between the EX and the LP i would go with the LP
Awd250
Suspension and Brakes
02-09-17 12:07 AM
slickster9
06-07-16 06:45 AM
chiem15
62
05-03-13 02:47 PM
ybbob
26
04-07-13 09:23 PM
PK_Celsior
83
09-30-08 07:21 AM
Quick Reply: what coilovers should i use ?
