Black Caliper's Rock!
#31
Northern California Regional Officer
I can't seem to find the hi-tem clear anywhere. I have checked three local places incl: Pep Boys, Kragen and Home Depot. Any ideas?
#32
exclusive matchup
#34
Synergy,
PM or call me if you want. My mailbox was full when you tried earlier today. I assume you wanted to know about the clear.
Since you and Rominl are following in my footsteps, take it from both of us. Follow the spray can directions to the letter or you will get wrinkling of the paint after about 1/2 hour. By the time you find this out, it will be too late.
Do no more than 3 or 4 light coats max and wait atleast 10-15 minutes between coats and take no longer than 1 hour to spray the last coat.
Let the paint dry atleast 2-3 hours before driving, but preferably don't do any driving with a lot of brake usage that will get the calipers hot for 24 hours.
It is very easy to apply the clear too thick and either drip and/or wrinkle if you spray too heavy. Also the heat from braking may also make the paint wrinkle if the paint is still fresh.
RMMGS4
RMMGS4
#37
synergy - I LOVE the black... only one problem... I was planning to do the black on my RX calipers because I hadn't seen any Lex w/ black calipers - so much for that! Oh well, GREAT work - very tasteful mod worthy of a Lexus.
#38
exclusive matchup
#41
Confused...
Synergy,
I got some of that Rust-Oleum high-temp paint in black at Home Depot and I did a test on a piece of metal before applying to my calipers... Thank GOD because that stuff is completely matte black finish - no gloss to it at all... It was the only black high temp paint I saw though - did the stuff you used specifically say it was "gloss" black? You did use the high-temp stuff right?
#42
exclusive matchup
Re: Confused...
Synergy,
Synergy,
#43
Re: Re: Confused...
Thanks rominl - I think kragen is an auto parts store, right? I think here in Wisconsin it's called Checker or Pep Boys or something like that - I'll look for the high gloss black engine enamel paint and check it out - probably going to use it to paint my cold air box for my intake too - it should hold up to the heat on that too right?
Thanks again!
Thanks again!
#44
exclusive matchup
Re: Re: Re: Confused...
Thanks again!
Thanks again!
something to look out for though. make sure you FOLLOW the instructions. paint THIN coats 15 mins apart, and do NOT paint anything after an hr. you will have to let it sit over night before you can drive the car the best, and you need at least 5 (i would say 7) days for everything to cue.
basically, it really stands up the heat after it's dried, but before that it's very sensitive
#45
Thanks rominl... that sounds reasonable about the curing time - it takes regular automotive paint like 90 days to fully cure under the clear coat - they don't even want you to wax it before that time.
I'll at least leave the car sit overnight before driving it after I paint the calipers...
