ordered brakes from sewell.
Technically those parts will work and they are the "right" parts. However...
Front's, you really should look into the alternative low dust pad imo, up to you I went back and forth, going back to low dust.
High-Friction Pad Part# is: 04465-30410
Alternative Low Dust Pad Part# is: 04465-30400
Rears are as follows, I don't really believe you would run into an issue running the one you have, most likely they changed the compound material not the physical dimensions of the pad.
04466-22190 is listed for early 2006 models.
04466-53010 is listed for 2006.02-on.
306mustang
Suspension and Brakes
46
11-30-18 08:17 PM
IS350HKS
23
05-30-09 06:33 PM
