Decided to "upgrade" rotors,need help.
Brands?
Pros?
Cons?
Should I/not
drilled only
Slotted only
Both
What pads for either set up.
Would like for my rotors to look like this
Doesnt matter if it exact patter or not I like the gold.
Thanks a lot search button didn't work.
Pros?
Cons?
Should I/not
drilled only
Slotted only
Both
Cost you money.
That's it.
Car will still stop in exactly the same distance it did before...
Oh, and if you go drilled you'll end up with cracked rotors eventually... slotted will be better there, but they'll still eat through pads faster than the OEM blanks, to no real benefit in street use.
Upgraded brakes do look nice though.
So to the OP I'd say:
Drilled: never. You're putting an inferior part on the car for looks, something I just can't ever recommend anyone does. Drilled rotors don't belong on anything but cars on a stage/at a show.
Slotted: GREAT idea if you track the car (as it does have benefits there that are worth the shorter pad life)... but if it's a street only car then the question is why upgrade at all?
If it's just for looks, well, slotted can look good, and again you'll give up pad life, but otherwise be fine.
The best, in terms of functionality and service life, for a street-only car is blank rotors though. And no need to go any bigger than stock unless you're doing it for cosmetic reasons.
thanks guys I figured its really just a waste of money since I dont track and I will definitely stay away from drilled (tho ive heard they only crack when tracked)
and yes... it is only for looks. I wanted gold rotors. slotted. red calipers. white or gold emblems
Assuming you don't run the car on a racetrack?
Cost you money.
That's it.
Cost you money.
That's it.
Fire Slayer
Just get slotted ones. If you're gonna change them already. I know you'll be able to see them with your wheel set up. Just make sure to get some that have some sort of coating on them to prevent rusting. The car guru Kurtz said slotted are best so listen to him. Good luck. I found these for you...http://www.autoanything.com/brakes/61A3527A0A0.aspx
That said, if you don't mind replacing pads more often in exchange for the "look" of it there's nothing wrong with using slotted on a street-only car, it'll work just fine...it just won't give you any functional benefit compared to blanks.
koreanpers
Suspension and Brakes
06-26-04 11:06 PM
