Replacing Lower Front Brace. Spec?
Old 09-28-11, 10:32 PM
gman44116
gman44116's Avatar
Default Replacing Lower Front Brace. Spec?
I need to get the torque specs for the LFB bolts. Can someone please help me with the
shop manual what the torque ft. lb is for these bolts??
Old 09-29-11, 08:25 AM
lyonkster
lyonkster's Avatar
If you mean the front suspension member brace, then it's 43 ft-lbf.
Old 09-29-11, 04:36 PM
gman44116
gman44116's Avatar
Leon, here's a pic of what I thought is named the lower front brace. The photo shows a TRD brace instead of the OEM rounded brace. But the mounting bolts are the same...
This is the one I need the torque specs for..
(pic borrowed from another post)
Old 09-29-11, 04:45 PM
lyonkster
lyonkster's Avatar
Yup, that's the one. Lexus shop manual calls it the front suspension member brace... 43 ft-lbf .
Old 09-29-11, 05:23 PM
gman44116
gman44116's Avatar
Thanks Leon. Maybe you can confirm one more torque spec.
Front end - lower shock bolt. I read somewhere here it is 116 ft lb. Yet, somewhere else only 70 ft lbs.
Can you help me confirm? thanks in advance
Greg
Old 09-30-11, 02:31 PM
lyonkster
lyonkster's Avatar
Greg
Greg, according to the shop manual, 116 ft-lbf is correct.
Old 09-30-11, 03:24 PM
vwynn
vwynn's Avatar
i just tighten it till its tight lol
Old 09-30-11, 06:37 PM
gman44116
gman44116's Avatar
Thanks again Leon
Old 09-30-11, 07:02 PM
lyonkster
lyonkster's Avatar
Thanks again Leon
No problem, any time!
Maltrix
Suspension and Brakes
08-21-17 08:04 AM
Scott1258
11-25-06 09:42 PM
GSquicksilver
09-15-06 05:48 AM
davezaristo
11-08-02 07:44 AM
nudderGS400
09-24-02 01:30 AM
Quick Reply: Replacing Lower Front Brace. Spec?
