DIY - Rear Axle Carrier (Knuckle) Bushing Replacement
03-03-12, 04:00 PM
The seller seems to get these in batches. Best bet is to contact him and ask to let you know when he gets a new batch.
04-09-12, 11:24 AM
I need these very badly, i just bought a 2gs and mine have excessive play. Does anyone have an extra set or know how i can contact the seller? I spoke with FIG and they are making is300 buhings, will these work? Thanks
04-09-12, 12:02 PM
i have a set.....took me a month or so to get from the ebay seller
04-22-12, 07:48 PM
Has a confirmation been made that the rhdjapan aristo rear axle carrier bushings the correct ones???
04-25-12, 05:18 AM
I contacted rhdjapan and they said these bushings are for trailing arm not the knuckle
04-25-12, 11:29 AM
Quote:
Originally Posted by
RoninEng
u sure YOU asked them about the right bushings. they do indeed have knuckle arm bushings and also trailing arm bushings
04-25-12, 04:00 PM
The ones Linked on the first page are for trailing arms. If you mean number 9 on the picture through the link I am trying to confirm them now
04-26-12, 09:07 AM
Just ordered mine from Carson Toyota $48 each. That have em in stock.
04-26-12, 09:08 AM
philv4572
Direct link?
04-26-12, 09:14 AM
philv4572
http://www.l-tunedparts.com/product/?id=3322
if youre referring to that then thats not the same ones as the OP.
04-26-12, 09:24 AM
That's the one I just ordered. Why isn't it correct part?
04-26-12, 09:52 AM
04-26-12, 10:04 AM
philv4572
It's for the trailing arm, not the control arm. Look at my post #88.
04-26-12, 10:05 AM
PHil is that link associated with the picture as #9?
04-26-12, 10:37 AM
sakataj
It's a bit more confusing than that Brian.. If you look at the picture in your link, it
looks like the right thing. But if you look at the drawing for item #9 in the diagram (below), that looks like the inside bushing, not the one on the carrier end. I'd check with rhdjapan first (maybe you already did).
