Front UCA proto pics
#33
Everything kinda slipped when business ramped up. I made one set of caster arms for a high HP car and have modified spacer adapers for the GS designed and being machined. I also have a press-in,adhesive installed bearing cup for a spherical conversion of the rubber caster bushing. Its being tested by an IS right now and once I have the spacers here it will go on a GS immediately.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#35
The bearing carrier is a Caster adjustment, the rod ends on the inboard side are the camber adjustment.
__________________
#36
To answer your question Tom, FIGS upper arm is has a bend in the arm to give extra clearance for slammed vehicles and less stress on the ball joint. Whether or not its enough clearance to stop bottoming out is something Mike would need to chime in on.
Any sneak peek photos of the new solid machined bent arms look?
#37
Tom is referring to the 3 exposed bolts poking out at the top by the ball joint which I believe will adjust the caster not the camber. Since that area usually bottoms out on the shock tower.
I am not going to have solid machined parts, just fully ridged bent sheetmetal. The ones that are pictured are close, I just need to actually weld them fully and not a few tack welds here and there like pictured
__________________
#39
I can't wait to see how these work, and if it stops us slammed GS owners from banging the shock tower all the time on big dips would be great!
I'm also waiting on the caster arms! no one would ever need to buy bushings again and no squeak....and far better braking response. I guess I'll hold off on buying new caster arms.
#40
A "noob" question. On the "front UCA" is the camber adjusted with the nut or are the rod ends removed and screwed in/out as needed? Also , what is the torque in the caster bolts so they don't slip on the first bump? What ball joint is used and where will I have to go for replacing when it wears out?
Now for the "rear LCA", what is the torque on the camber eccentric nut?
#41
Torque on the camber eccentric nut for the REAR LCA is
Torque: 110 N·m (1,120 kgf·cm, 81 ft·lbf)
__________________
#42
okay on the upc ,i know on The website that there is no specific date ,but i am in need of these arms i am trying to hold out
so i will not buy spc,ikeya .BTW mike i can not find your rca on the website
#43
cant wait to get these, and the caster arms.
Or a whole "front end lowering kit" of fig's parts
#44
I will put the RCA's up in the next few days. Been just taking orders via email for way too long haha.
__________________
