Front UCA proto pics
Old 10-12-11, 09:37 AM
FIGS
The Maker
FIGS's Avatar
Default Front UCA proto pics
Adjustable caster and camber, plus and minus. Still working on fitting them up, these are just tacked to maintain geometry in case I need to make adjustments.
Upper sperical is a Aurora Teflon lined precision AM series. Chromo tapered stud, .125 wall sheetmetal.The final design will be fully machine bent, this was laser cut at the bend lines to make it easy to assemble and verify.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-12-11, 09:41 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Nice work FIGS.. quality craftsmanship
Old 10-12-11, 10:31 AM
sakataj
sakataj's Avatar
cannot wait to get these
BTW mike i let the cat out of the bag earlier in here
https://www.clublexus.com/forums/sus...trol-arms.html
for those who dont stalk you on FB like i do, just kidding
i know you said these were just tacked mike but on the production version will all the machine bends be fully stitched up? i assume so but maybe not and on the actual control arm that bolts to the car (not th ball joint) is there gonna be something on the underside actually wrapping the spherical bushing? if not wouldnt a good pothole or something be able to break that weld in the long run?
Old 10-12-11, 11:01 AM
FIGS
The Maker
FIGS's Avatar
Not sure what you mean. You mean on the inner mount? Everything will be 100 welded in final product, like I said, that includes the entire edge along the sides an on the end fitting mounts on the inboard side. Potholes are taken up by the shocks, not the upper. The only loads are lateral or if it were to bottom on the inner fender.
__________________
Old 10-12-11, 12:17 PM
sakataj
sakataj's Avatar
yes mike thats what i was asking.....lol ty
Old 10-12-11, 12:58 PM
FIGS
The Maker
FIGS's Avatar
the best way to think of it is if there is a slot, it will be either filled with weld or it will be solid.
__________________
Old 10-12-11, 04:50 PM
tmf2004
tmf2004's Avatar
Any plans on making front and rear sway bars like the TRD or Daizen set?
Old 10-12-11, 06:18 PM
lunatyk
lunatyk's Avatar
NICE! I need this!!
Old 10-12-11, 07:19 PM
FinLIFE
FinLIFE's Avatar
These are niice. Do you think pricing will be anywhere close to spc arms? I know the quality is much better in your products, but im no baller
Old 10-12-11, 08:32 PM
vwynn
vwynn's Avatar
i wonder how much of a beating it can take from bottoming out a lot from slammed guys
Old 10-13-11, 08:46 AM
FIGS
The Maker
FIGS's Avatar
No plans yet.
Pricing is still TBD. Since I mane some of these parts a year ago, I need to get current quotes to verify final cost. Targeting a similar price to SPC.
__________________
Old 10-13-11, 09:21 AM
sam430
sam430's Avatar
since there are pulling action, maybe flip this around and box it? that way, there is a stop if the weld don't hold...lol. just an observation. looking forward to it.
Old 10-13-11, 10:04 AM
sakataj
sakataj's Avatar
thanks sam....that essentially is one of the things i was asking in post # 3
mike did address the other one i asked about the filler... but i would think those need to be boxed up also
Old 10-13-11, 10:14 AM
FIGS
The Maker
FIGS's Avatar
I think you guys are overthinking this, but of course I take all feedback. It will have an enviroment box, but it already has a U channel and there are a few gussets I have left off in this area. remember this is an upper and does not see the load of the shock, just lateral and steering loads. Significantly higher duty Trophy trucks get away with some pretty thinwall UCA designs. These are .125" wall, the stock are .062" or less.
__________________
Old 10-13-11, 11:26 AM
sakataj
sakataj's Avatar
probably mike and i will be the first to admit i know nothing about the design/process needed for making these, they were kust observations i made....i have always trusted your judgement and will continue to do so, so if you say this is more than enough to handle the stress of driving than im with you...
Quick Reply: Front UCA proto pics
