Quick Caliper Painting Question
I would not spray paint them, I would brush paint them. So if Duplicolor is spray-only, don't do it.
I highly recommend G2. It's proven, and I see it used most often here on CL. I used it and got perfect results. The whole kit is only $40 on Tirerack.
here is a picture of my ugly painting skills with the G2 paint kit!!! I would recommend a better brush like everyone else has told you!!! I used the janky one that came with the kit and you can see some of the bristle stuck within the paint. i did mine spare of the moment and got to lazy to pick up another brush
Here are my results with G2 paint and a high-quality art supply brush: https://www.clublexus.com/forums/sus...ml#post6673799
Duplicolor is spray, right? Or do they have brush-on?
Gotta debate which color still haha
i have the duplicolor (brush) on my calipers for... 4yrs now, wipe my calipers with a damp mf towel and it looks as fresh as the day i painted it.
There is one problem with painted calipers thou, sometimes when you pull wheels to clean the inner barrels/wipe down wheelwells/wipe down suspension you COULD nick them (calipers) as you pull off the rim. So make sure you keep the xtra paint for touch ups and/or make sure you can get the same color paint and not some custom mixed color.
and yes i do pull wheels once a month to wipe down everything in the fender
I used the duplicolor kit as well. Came out nice I think.
I did 2 regular coats, the stuff dried fast, so I only had to wait 30 min inbetween coats
Then I did a quick "leveling" coat
Waited 2 hrs and applied the decal
Then I sprayed them with High-Temp Clear to make them glossy and protect the decals.
If you take the caliper off the hub (not the lines) and let them sit on a bucket, you can get ALL the areas that might be seen with the pads out...
