Bump steer
Old 10-23-11, 08:47 AM
jonIllest
jonIllest's Avatar
Default Bump steer
i have some pretty noticeable bump steer after lowering the car with coilovers
will a front RCA set solve this issue?
i'm not familiar with where exactly RCAs are installed and how they would affect tie rods, if at all
Old 10-23-11, 10:46 AM
GSteg
GSteg's Avatar
RCA will reduce bumpsteer only if you raise your car back to your current height. So the height of your car should be the same before and after the RCA.
Old 10-25-11, 11:48 AM
jonIllest
jonIllest's Avatar
oh ok
ideally, i'd like to keep the car at it's current height without the bump steer issue
thanks for the reply
Old 10-25-11, 12:14 PM
5t341th
5t341th's Avatar
it pushes the lca down so its more parallel with tie rods
Old 10-25-11, 09:05 PM
vwynn
vwynn's Avatar
you gotta get lower tierods. since youre lowered they sit at an angle... gotta make em as parallel to the ground as possible.
Old 10-25-11, 11:51 PM
GS4_Fiend
GS4_Fiend's Avatar
the higher the LCA is, the more bump steer and loss of traction will happen.
Meraki Autoworks
Club Lexus Vendor Marketplace
158
10-04-17 10:29 AM
Acura2Lex
30
02-08-14 06:23 PM
SimplyZBes
General Classifieds
03-23-12 12:13 PM
snook
Wheels and Tires Classifieds
09-18-09 10:50 AM
Quick Reply: Bump steer
