Weird noise coming from passenger rear axle
I took the wheel off for a closer look but didn't notice anything worn or out of the ordinary.
The sound is like a light metal clanking noise similar to the noise made by the front lower ball joints before they failed.
The noise happens mostly at idle speed and more so on turns. W the car in park if you push the car from one side or the other, the car will also make the sound.
After inspecting and finding nothing wrong, I put the wheel back on and the noise goes away for a day or two but unfortunately comes back
1998 Lexus gs 300
Thanks in advance.
1998 Lexus gs 300
Thanks in advance.
1998 Lexus gs 300
Thanks in advance.
1998 Lexus gs 300
Thanks in advance.
https://www.clublexus.com/forums/sus...placement.html
well, your assuming I know what a knuckle is or what a bushing was before reading the thread.. all I knew was weird noise.. I needed help making that connection. Any way, Thank you very much for the heads up! Lexus wanted $65 just for diagnosis which I was going to pay but they then said 2 hour wait.
Is there any danger of driving w/ this condition or is this merely an annoyance factor?
