Major lower control arm woes with pics...
Ok update: 97-00 had a bigger front ear on the control arm which is the same id as the rear bushing but shorter so there is no way to get the bushings in a 97-00 lca with out Jerry rigging it which is not how I roll so the only question I have from you guys is can pre 97 control arms work in a 97 chassis? if not then why?
Ok good to know^^ I know 97-00 had this style of lca and these bushings are for 92-96 so I just screwed up a good lca which I found some good lca's from a 93 at the yard for fairly cheap so I will just install these bushings in those and bolt them up and hope there is no ill effects.
whats fairly cheap??? man i feel bad when ppl go on a mission... no one ever helps me but i like helping ppl...
like i mentioned earlier dude, i have a set of 95 LCA. if u pick them up u can have them. spending money on stupid sh* T annoys me... and i dont need them.!
Solo_D33A
Suspension and Brakes
11-18-09 12:39 AM
