97 sc300 break upgrage
I'm new here an I have a sc3 an I'm about to try an fit drilled an slotted rotors off a gs300 I'm pretty shure they the gs caliper wil fit on the sc3 spindel has anyone done this before id like some ideas
Hey man. If your wanting to up grade to a "BBK" Big Brake Kit. Then you have a few options. (1) Is do the LS400 brake's. These are the cheepest setup. You can find them for around $150-$300. They are 4 piston calipers & are direct bolt on, but you have to get the LS rotor's also cause they are bigger. You also have to remove the SC300 dust shield, cause the bigger rotor will not fit. (2) Is the Supra TT brake kit, which will cost you around $500-600. The rotor's are 12.7" & the calipers are also 4 piston. (3) Is Stoptech or Brembo BBK & they will run around $1800-2600. If all you are looking to do is, just change out rotor's to a drilled & slotted rotor for looks. Then just go to www.irotors.com & you can buy 2 front rotors shipped for like $80.
I feel like if I wanted a smart as answer I'd ask a smart as question ... anyways. Ill have to lookin to the ls400 calipers also I have gs300 rotors. An I Juss wanted a cheap big "break" kit. Thanks for good input. An shurly this should go under Suspension and Brakes
97, bbk, big, brake, club, clublexus, compatible, gs300 2nd gen, lexus, lfa, ls, ls400, rear, sc300, suspensions
