Dual Calipers
Old 11-07-11, 07:46 AM
OBEEWON
OBEEWON's Avatar
Default Dual Calipers
I have been looking into a way to lock the rear wheels easier/more consistently than the stock drums.
Has anyone ever seen or done a second rear caliper for the SC or Supra?
My searching has yet to show anything.
Old 11-07-11, 05:48 PM
FORTYSIXn2
FORTYSIXn2's Avatar
I believe there are a few out there for R34's if you have the means to make your own brackets to adapt them.
Old 11-08-11, 09:33 AM
ArodDaLob
ArodDaLob's Avatar
I've personally never seen a dual caliper setup on an sc, the most i've heard is getting aftermarket brake shoes. I would friggin love a dual setup though. Sounds like something pbm needs to start making
Old 11-08-11, 10:59 AM
Oxford
Oxford's Avatar
http://www.ksportusa.com/asp/hydraulic.asp
About the only thing I could see being able to install on the SC. Few guys have them locally and drift (From ur sig you probably do too) and they swear by them.
Old 11-26-11, 04:50 AM
greens14
greens14's Avatar
^ i think he means something like: http://az240sx.org/forums/index.php?...706&hl=caliper
anyways one of our local engineers does cnc work. I'm sure you could contact him for a custom design. Not sure what he'll charge but give it a shot. His post is in that thread.
Old 12-02-11, 07:12 AM
OBEEWON
OBEEWON's Avatar
Thanks for the replies guys. I think I may look into making my own bracket and using a wilwood caliper in conjunction with a staging brake. Will probably be expensive!
Old 12-02-11, 07:44 AM
Luv2xl
Luv2xl's Avatar
hold the phone.. you decided to keep it and swap over the parts? man.. make up your mind.. lol
Old 12-02-11, 09:24 AM
Ali SC3
Ali SC3's Avatar
I have seen a local SC over here bust some nice drifts with the hydraulic setup.
Old 12-02-11, 09:49 AM
DoriSaru15
DoriSaru15's Avatar
^ i Agree. I would go hydraulic
Old 12-28-11, 01:17 AM
Cleanshots
Cleanshots's Avatar
i was actually thinking making a bracket for another oem sc rear caliper or two is300 dual piston or gs300 dual piston calipers.. or use one dual piston as main and the oem sc as the ebrake.. didnt know there was interest for this..
Old 12-28-11, 02:42 AM
spdrcr771
spdrcr771's Avatar
This is really, about what the OP is trying to do with his brakes. What I meen is, there is no reason to do a dual caliper set up for road racing. All you need to do is "SPEND THE MONEY' on a good system, like Stoptech. Other wise if your trying to do nothing but drift then just buy the LINK above. No need for trying for something outragious, just to save money on buying what is out there & already proven, cause you wont...
Old 12-28-11, 04:46 AM
greens14
greens14's Avatar
^ I'm guessing youre typnig from mobile because i cant really understand what youre trying to say. But yes im sure its for drifting or some other extreme driving; dual caliper setups are most often used so you can rip the ebrake at anytime without compensating main brake pedal feel
Old 12-28-11, 12:23 PM
MIKU*SC3
MIKU*SC3's Avatar
Its weird because i just saw someone post this on my FB.
If they can make it for the 240 then i would think they can for the SC.
http://zilvia.net/f/brakes/426702-s-...ml#post4428587
Old 12-28-11, 12:34 PM
OG Dada
OG Dada's Avatar
Woah! That's dope! If anyone can make that, I'm in! I hate the dumb brakes...
Old 12-28-11, 12:42 PM
spdrcr771
spdrcr771's Avatar
No actually typing from my PC. All my words are spelled correctly, may want to check yours haha. Also when you read the OP's original post. He says "DRUM", which actually is only used for the parking break. He never said anything about "drifting", so I didnt assume anything. If one wanted to use a rear locker for drifting, then the link above would be the tool/part you would want to use & it would be connected to the caliper, not the drum. So let assume for just a sec that he was talking about road racing & he had the idea that if he mounted 2 stock calipers onto the rear rotors he would get better braking. It would cost alot more to fab the brackets, run the lines, & buy the caliper. Than just buying TT Supra rears or brembo/stoptech rears. Thats what Im saying...
Quick Reply: Dual Calipers
