brake job question...
Old 11-09-11, 05:08 PM
MsbTTSupra
MsbTTSupra's Avatar
Default brake job question...
I am in the process of doing my 98 gs300 brakes. Everything was going well until i tried to re-install the calipers.
I noticed the caliper wold not go back on (depressed the pistons). The caliper itself hits the caliper bracket mount bolt.
Now on the mount bracket, the top hole will move in and out, bu the bottom one is stuck solid. I have tried everything to make it move.
Question is.......are both mount holes/bolts on the caliper bracket supposed to move freely, or just 1, or are they both not supposed to move?
Old 11-09-11, 05:19 PM
Mikeyy
Mikeyy's Avatar
It's a sliding caliper design, which means, both sliders pin are suppose to slide, your bottom caliper bolt is probably seized... try wiggling the bolt back and forth and see if it comes out, if it does then lubricate the bolt and reinstall it, then you'll be good to go.
If it doesn't come out you have a few options, spray from penetrating oil on the bolt itself and wait a few hours, then try again and see if it comes out. If it's seized in there, chances are you might need a new bracket, I seen brackets seize up numerous time due to lack of lubrication and maintenance
This is the 3GS section btw...
Old 11-09-11, 05:20 PM
MsbTTSupra
MsbTTSupra's Avatar
i may have screwed the bolt up............i got pissed off and tried to turn the bolt with some force. Looks like the bent the bolt a little.
Wonder if i can pull the bolt all the way out and install a new one?
Old 11-09-11, 05:30 PM
MsbTTSupra
MsbTTSupra's Avatar
anyone know the part #'s for...
the sliding bolts
rubber boots
Old 11-10-11, 07:58 AM
Infamous 1
Infamous 1's Avatar
You would probably have better results if you tried the gen2 (98-05) gs section.
Old 11-11-11, 12:25 AM
vladbph
vladbph's Avatar
Done it, same thing - had to change both calipers in the rear.... I was told keeping the car in the garage in wet climate is very bad - bottom pins stuck for good. When changing calipers don't forget to put more grease on the pins.
Old 11-11-11, 05:27 AM
tunedis95
tunedis95's Avatar
done it to....i ended up working both of my stuck rear brackets with lots of luvin with a hammer and lube. They were stuck real bad...Worse brake job ever....should be good now
replaced
PIN, REAR CYLINDER SLIDE, NO.2 (FOR REAR DISC BRAKE)
Shipped $9.13 2 $18.26
BOOT, BUSH DUST(FOR REAR DISC BRAKE)
Shipped $3.48 1 $3.48
jiggawho
IS F (2008-2014)
03-20-15 08:43 PM
endlesslex
06-10-14 01:30 PM
chenxingha
RX - 1st Gen (1999-2003)
08-16-08 06:08 AM
MNeier
Wheels, Tires & Brakes Forum
04-27-04 02:56 PM
Quick Reply: brake job question...
