strange brake problem (gs300)
Old 11-11-11, 08:32 PM
eyik66
eyik66's Avatar
Default strange brake problem (gs300)
I was driving my car today, and as I was coming to a stop (several times) the pedal would suddenly give out if that makes sense. In other words, I would be coming to a stop with the brakes feeling normal, then suddenly the pedal would just loosen up and dip down. i would have to press the brake harder to come to my stop. It seemed like there was a little bump felt first in the pedal before it dropped. Any ideas?
Old 11-12-11, 04:34 AM
jeepandlex
jeepandlex's Avatar
u better get under ur car and check for leaks.... check the inside of the rims......usually there is brake fluid spattered all over the inside. Did u let the resevoir go dry and add fluid???? just some ideas
Old 11-12-11, 05:35 AM
porn-adkt
porn-adkt's Avatar
Yes, you need to search, it has been covered many times including by myself.
Old 11-12-11, 09:11 AM
850Lexus
850Lexus's Avatar
Very informative post!!!
Sounds like air in your lines somewhere. Check for leaks and bleed brakes. ABS can be very hard to get the air out, you just have to do it over and over till you get it.
Old 11-12-11, 10:09 AM
eyik66
eyik66's Avatar
so I did add fluid to the reservoir. The brake light was on because the fluid was low. I'll check for leaks then? I'm guessing you don't lose brake fluid unless there is a leak. Thanks for the help guys, I just bought the car and I'm trying to get this thing running right so I really appreciate it.
Old 11-12-11, 02:20 PM
porn-adkt
porn-adkt's Avatar
Im not gonna SEARCH for you.. Good luck if you think its Air.
Old 11-12-11, 02:51 PM
eyik66
eyik66's Avatar
look, I did a search, but I didn't find my problem. . I'm not the king of keyword searching
Old 11-13-11, 05:58 PM
tommyGS3
tommyGS3's Avatar
i had the same problem...one of my front abs sensor was going bad...fix the problem and this issue never came up again...
Old 11-15-11, 02:43 PM
eyik66
eyik66's Avatar
was there an error code that is associated with the abs sensors that I should look for?
Old 11-15-11, 03:12 PM
TWong350
TWong350's Avatar
****-adkt exit this thread. Do not reply in it anymore.
abaitedcat
Suspension and Brakes
03-01-19 02:28 PM
tb13
07-05-16 05:51 PM
CMACE23
11-04-14 09:00 AM
Lexus082
06-21-11 05:39 PM
gcam77
02-06-08 08:53 PM
Quick Reply: strange brake problem (gs300)
