09 is250 caster bushings [replacement help needed]
Help with adjusting caster on my 09 is250. Any pics and info appreciared. Thanks
Any update on this? I got new tires installed on my stock rims and stock suspension but now all of a sudden my front drivers side tire rubs when I make a hard left.
I know my car was hit once before with front end damage, and always noticed that the front drivers side tire is not centered to my wheel well, and passenger side is good. Any idea what it may be, how to fix? I read that it may be bushings. Comments?
Are you sure it's caster? It may very well be camber you need help adjusting. FIGS is coming out with an adjustable front upper arm that will adjust camber and caster.
As of now, there's no products to adjust caster. SPC makes an adjustable ball joint to adjust camber.
