parking brake question??
lately i've notice my parking brake is not as firm and tight as before...i can step all the way in and park it on the drive way and it still move a slight bit..i tested other gs's and it feels alot firmer..anybody know how i can firm up my parking brakes or tighten it??
Master Thread Closer!!
Tommy,
To adjust the parking brake firmness, you need to remove the rear tires. On the rear rotors...both sides...there is a dime-sized rubber grommet covering a hole next to the wheel bolts. Remove the grommet. Use a flashlight and a flat head screwdriver, adjust the mini spindle wheel to tighten. Make sure to count how many times you turn it...and do the same on the other wheel.
I forgot which way is to tighten or loosen...up or down...i guess its trial by error...lol.
If I find it in my service manual, I'll post it up.
Goodluck.
Pete
Goodluck.
Pete
