L-tuned or Eibach Springs: Which one is REALLY shorter???
Old 10-09-02, 02:49 AM
whitels
whitels's Avatar
Default L-tuned or Eibach Springs: Which one is REALLY shorter???
I have searched pages and pages of CL info but got nothing definitive about which of the two will provide a lower drop? There's a lot of numbers thrown around but nothing that sounded certain for sure.
Would someone who knows it pls. respond? I need to make a decision quickly. Thanks MUCH!!!
I already know that Eibach made the L-tuned but I'm still of the impression that the two are physically different.
Old 10-09-02, 02:55 AM
GS4Will
GS4Will's Avatar
white...
to a great extent, i firmly believe that Eibach will not make a springs JUST for L-tuned...too much cost is involved...just my $0.01.
Old 10-09-02, 11:46 AM
whitels
whitels's Avatar
Originally posted by GS4Will
white...
Absolutely agree with your logic. But when I searched, I found that some members would say that the Eibach is stiffer than the L-tuned, or the L-tuned would drop the car more than the Eibach, still others would say the complete opposite. These discussions confuse me since these guys must be seeing a difference between the two springs. I'm hoping that anyone with direct knowledge to say that "Yes, they are one and the same", or "No, the L-tuned is a softer spring than the Eibach". Maybe I should take a poll but someone here must definitely be on the know. GS4will, thanks for your input.
Old 10-09-02, 02:36 PM
GS4Will
GS4Will's Avatar
white...
funny you brought up this topic as i was just comparing some specs the other day on several different spring after i have seen HR, Eibach and my jdm springs.
Eibach gives the least drop, F(~25-30mm), R(~10-15mm)
HR spec says "1.4/1.2" drop..but the actual the down is not as much as my jdm springs of 35mm/30mm...visually, a significance.
on the spec sheet, both should drop about the same.
also the Eibach have higher spring rate, though with lesser drop, it actually is slightly firmer springs.
Old 10-09-02, 04:08 PM
whitels
whitels's Avatar
white...
Hey GS4will...
Good stuff- thanks! How do you like your JDM springs?
Old 10-09-02, 04:13 PM
GS4Will
GS4Will's Avatar
sure...they are might comfy..and the lowered LOOK...
i was a bit concerned before i put on 18x9+10 +37 offsets f+r..but no rubbing at all:eek:
robpat143
02-26-06 12:29 PM
Alexus-Kia
06-29-05 07:53 PM
shadow
Suspension and Brakes
11-21-03 07:44 PM
whitels
13
08-24-03 11:43 PM
Quick Reply: L-tuned or Eibach Springs: Which one is REALLY shorter???
