Figs toe links
Figs toe links
Hey guys, I'm a bit noob on this topic but I wanted to see if experts can confirm.
Most tire wear on our cars come from the toe, when your dropped to no fender gap on coil overs can the stock system adjust the toe back to 0? (I plan on changing tires and getting an alignment after to get specs)
If the stock system doesnt allow it, would the figs toe links fix this problem? I don't want to spend a ton of money on things such as their mega arms, so this seemed like a good solution if it can fix toe and tire wear.
http://shopfigs.com/v1/index.php?rou...&product_id=81
George, I had my toe back into specs without links. The only arms I have are megan camber arms. I told the shop to go as negative the arms can go and correct the toe.
thanks for the replies guys. I think im going to just go in for alignment and if they cannot get toe in spec go for the links. thanks again guys! quick and informative.
I have noticeable bump steer with my suspension currently dropped on BC Racing coils with tucking tear tire, but there's still gap. They can't get any more toe, and I'm doing suspension work this winter with SPC Front ball joints and the FIGS rear arms with toe links to hopefully correct uneven tire wear and the bump steer. Hopefully we'll both find corrections to our toe problems.
