Camber Kit questions
I have 20x10 +20 with 245/35/20 tires in the rear of my IS350:
the wheels are about 1/2" sticking out, cant go any lower cause its rubbing ..
I want to camber them about 1.5 degree, is that enough?
saw this one:
![](http://www.horsepowerfreaks.com/images/products/Megan_Racing/Camber_Kits_MEGA_MR-6392_LRG.jpg)
and
![](http://i.ebayimg.com/05/!BnmydKwBGk~$(KGrHqEH-CEEt67+E4dFBLkI(-p)9!~~_12.JPG)
Which one do I really need just to tuck my tires without rubbing..
thanks
this is how it is now:
saw this one:
and
thanks
![](http://i200.photobucket.com/albums/aa122/myredz/Avant/_MG_1680_800.jpg)
Man, they are really sticking out there aren;t they? You're probably at the factory neg. camber ( about - 7 deg.)
I'm not sure if the Megan's are set up to increase the neg camber any further just to correct the camber to a less neg. setting. I read that somewhere in one of these threads on suspension. I may be wrong. If you can get another -1.5 camber it'll give you more room for sure, enough to stop rubbing, I'm not too sure.
i think about 2 more deg because my cousin had some work wheels in his 05 accord and he had to go -7 camber because the wheels where sticking out about a inch and a half or 2. So you would be ok and btw the concave looks sexy!
ultran00b8
04-10-15 07:22 PM
