megan lp coilovers clunk noise
a few days ago, i drove over steel plates on my 2gen gs300 without braking cause i didnt see it. and now the front left coil is clunking louder than ever. i dont find the other coils a problem except for the driver seat front side. anyone that has any idea whats wrong can you lmk please? thanks alot.
swap out the top hat with your stock and see if this will cure the problem. I did the same thing with my JIC coilovers. I was on the freeway and litterally jumped my car over a steel plate in a small construction spot on the freeway. Closer home i heard the noise and the car felt different. i got home and realized i had a few bent wheels. Put on the stock wheels while the wheels were repaired. The noise was still present so I inspected the suspension and found nothing. tried recreating the sound by jacking up the rear hub and dropping it but came up with nothing. finally decided i would put in stock struts and see. After I did the sound deceaced. since I couldnt swap out the bottom I swapped out the top hat. While doing so I realized the had been shredde inside the top hat. I had to mod the stock top had, and had no pillowball. BUT the clunk was gone.
stlgrym3
Suspension and Brakes
05-02-13 06:05 PM
BayAreaLex
11-26-12 04:46 PM
