Rear brakes seizing
Old 11-30-11, 09:39 AM
oblivionis
oblivionis's Avatar
Default Rear brakes seizing
The driver side rear brakes on my IS350 are seizing. They overheat and the brake pads are nearly worn out and I just replaced them last year. I took off the caliper and lubricated the sliding pin but that did not help. The caliper slides back and forth but the sliding pin fitment is not snug and if the caliper is pushed at an angle it won't move. Would replacing the sliding pin help? Or do I have to change the caliper? If so, go with OEM or aftermarket?
Old 11-30-11, 12:15 PM
hybridanim
hybridanim's Avatar
I had the same problem replacing my driver side rear brake. The caliper seized on mines also. Theres a TSB on this. Take it to your local lexus dealer and they'll replace the caliper for you.
Old 11-30-11, 12:32 PM
new.era.13
new.era.13's Avatar
i believe we is out of warranty, so i don't think he can get eh tsib.
Old 11-30-11, 12:50 PM
uz07lex
uz07lex's Avatar
I had the same problem i just changed the calipers on both side. Worked great ever since.
Old 11-30-11, 01:00 PM
scweetrob
scweetrob's Avatar
My sc did the same. I noticed I was low a brake fluid. But then my front ones did the same. And the piston ended up being stuck
scweetrob
scweetrob's Avatar
So I changed both front calibers, pads, and lines
Old 12-01-11, 01:47 PM
oblivionis
oblivionis's Avatar
Yeah, I'm out of warranty. Looks like I need to change the caliper. From what I'm hearing this is a design flaw . I hope this has been corrected in the new calipers.
Old 12-01-11, 04:07 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,990 Likes on 2,414 Posts
There's no sliding in the IS350's calipers. They're rigidly mounted like the Supra and unlike the SC.
FWIW, this seems to be a problem across a number of Toyota products. The wife's Scion tC had the same issue with the rear caliper pin sticking. I managed to get it off the pin and cleaned everything up, then greased with a molydisulfide wheel bearing grease when I reassembled. No more issues at all.
Old 12-02-11, 10:08 AM
oblivionis
oblivionis's Avatar
That's what I did too (twice) but it did not solve the problem. I think the issue is with the pin fitting very loosely in the hole and jamming when the caliper moves.
I should also add that this is my second caliper. Last year when I went to change the rear brake pads I couldn't do it because the sliding pin was "welded" into the caliper. So I bought a remanufactured caliper from ******************. Now, a year later I'm experiencing this problem. I ordered an OEM caliper from Sewell so this better solve the problem.
Why doesn't Toyota use two sliding bolts like other manufacturers instead of one sliding bolt and one sliding pin???
Old 12-07-11, 08:24 AM
oblivionis
oblivionis's Avatar
Update: I replaced the caliper and the problem is gone.
Old 12-12-11, 02:45 PM
JETLEX
JETLEX's Avatar
Thanks for taking the time to update (not everyone does).
manstice
16
06-16-18 10:10 AM
Drcoffee
RX - 1st Gen (1999-2003)
16
06-25-17 03:53 PM
justYnG
11-28-16 01:16 PM
gridlock13
06-18-11 02:25 PM
pinoybboy
Suspension and Brakes
05-02-06 03:51 AM
Quick Reply: Rear brakes seizing
