Wobbles
Just curious if anyone else has this problem, I have a 93 with stock suspension and 18's and whenever im on the highway or going over..ill guess 70 (broken speedo), I can feel the car wobble. Anyone have an idea as to why this occuring? My guess is the car just sits wayyyyy to high and at those speeds it wobbles back in forth when Im on the throttle. Any input is appreciated, thankyou!
I also realized my tires bald lol and it started when i put the stock suspension back on, when i bought it it had springs and the 18s, i switched to stock and a month later is when i began noticing it. I have rear control arms waiting to b put on when i buy coilovers, think fronts will also need to be switched out?
Your bald tire, tire pressure, old shocks, wheel size, and the size of your stiff tire sidewall is all associated with the issue you described.
Im in the same situation, took my coilovers off and installed my stock suspension with my 18x9s having the same issue. All my c/a bushings are good, so are my sway bar end links.
This didnt not happen on my stock suspension with stock and softer wheels/ tires that was designed for this car
I recommend going with aftermarket suspension to compensate the ride with your 18s![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'm not an expert, but this is what I summed up from my calculations and experience.
if you switched shocks and springs and didnt get an alignment thats your problem or if the 18s came with the car didnt have hubcentric rings it adds to the problem...your tires arent bald cus the car is lowered its cus your alighnment is incorrect or your tires had the incorrect pressure your doing alot of uneccesary things man you should have left the car as is and get a alighnment and new tires
Turns out my rear control arm was slowly seperating itself from the wheel. I now have coilovers and my megan arms will b put on when i get new bolts for them. Just an update for anyone curious.
