What suspension parameters can they be adjusted?
Without changing the suspension control arms, what other parameters can they be adjusted beside front toe angle?
Rear Toe?
Front Camber?
Rear Camber?
Rear Toe?
Front Camber?
Rear Camber?
Keeping it Real
Toe is all that has adjustment, yes. Sometimes alignment shops will push the arm, or shift the subframe a bit to try to correct other issues, but the only actual adjustment on the RWD cars is front and rear toe. AWD cars also have front camber adjustment.
EDIT: As per lobuxracer's reminder, yes front caster can also be changed, but only to one of 3 set positions by replacing the front lower control arm rear bushing. If you need to adjust caster, hopefully one of the other +/- caster bushings will bring it closer to spec.
Jeff
Jeff
Tech Info Resource
Not true at all. Front and rear toe are both adjustable on all 2IS models. No camber adjustments, and caster adjustments require replacing the rear LCA bushings, so it's pretty limited and expensive.
Keeping it Real
The front caster can be changed by replacing parts, I don't consider that adjustable, though I reckon that's splitting hairs. It can be changed if you order the +/- offset rear bushings, you are correct about that. Your selection is somewhat limited though.
I meant to say front and rear toe before, my apologies for the omission, I've edited my post for clarity.
Jeff
Jeff
Tech Info Resource
Check out FIGSENGINEERING.COM and look at their rear "lower" arm camber adjuster and their front "upper" arm "camber AND caster" adjuster, they are awesome, pricey but strong looking. If you need more toe adjustment they also have toe links for added correction.
caster adjusters bushings
Jeff
Jeff
Keeping it Real
You'd need to buy the bushings from Lexus. +/- 20' is the adjustment range.
RH Lower Arm Bushing/Bracket
+20' : 48075-30040
0' : 48075-30030
-20' : 48075-30050
LH Lower Arm Bushing/Bracket
+20' : 48076-30040
0' : 48076-30030
-20' : 48076-30050
Jeff
+20' : 48075-30040
0' : 48075-30030
-20' : 48075-30050
+20' : 48076-30040
0' : 48076-30030
-20' : 48076-30050
Jeff
Thanks for the info.. Doesn't the +20' put it way over the factory spec. of 8.8?
Keeping it Real
No, the factory specs are as follows:
2WD:
16in. Wheels: 8°07' +/- 45' (8.12°+/- 0.75°)
17in. Wheels: 8°11'+/- 45' (8.18°+/- 0.75°)
18in. Wheels: 8°04'+/- 45' (8.07°+/- 0.75°)
4WD:
17in. Wheels: 4°38' +/- 45' (4.63°+/- 0.75°)
The important information to take from that is that there are 60' in 1°, so the caster adjustment available via changing the bushing/brackets is +/- 0.33°.
Jeff
2WD:
4WD:
Jeff
Jeff ..... Great info, Thanks for all the input.
I'm gunna get FIGS rear lower arm camber adjuster and FIGS upper arm camber and caster adjuster when they come out. Have a great CHRISTMAS and Happy New Year to ALL !!!!!!!!!!!!!!!!!!!!!!!!
alexkidd
07-18-17 06:21 AM
07, 2009, 2011, 250, 4807530030, adjust, adjusted, adjustment, adjustments, awd, camber, caster, is250, lexus, rwd
