Steering Rack
Steering Rack
So my steering rack is cracked, I was wondering if anyone is parting out an 93 sc300.... I will also like to know if I can replace the it by myself with 2 jack stands and 2 manual car jacks. how long will it take? thank you
i can help
i have 1 in good shape im n ontario 100$ good bushings sence they r always bad, no play and no crakes n boots its a good rack. yes u can do it ur self it isnt really that hard id say the hardest thing is reataching the steering colum to the rack its a tight squeez, i should take u about a hr or so ur gna get oil on u when u take out old 1 the is 4 main bolts and nuts that hold it dwn 1 steering bolt and 2 oil line feeds and 1 plug 4 sensor thats it and tools u will need a 19mm a 12mm a 17mm 10mm a hammer a ball joint remover, box open end 12mm and i might b forgeting a size but i honestly dnt remeber all but thats most of it and i like to use the bigger 1/2 drive so its got more leverage. so if u need ne other help hit me up 4 more tips or the rack n pinion its self. ohh and just make sure dnt lose the washers that connect the fulid hoses to the rack if u loose them or even 1 ur rack will leak like a sap good luck brtha
thank you very much for the help as i have found the rack and pinion, i just read the forum for it and i will see if i can do the repairs with my brother! thanks for being so friendly :]
