Just did a custom alignment and this is like a new car!!
So I have a few suspension mods and just re did the inner and outer tie rod ends as well as poly control arm bushings and the alignment was the last thing to tie everything together![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Front camber is -1.3
0 toe in front
0.8 positive caster
Now this totally changed how the car feels and responds for the better so if anyone is on the fence about it I would say this should be high on your list.
I really don't like so much - camber but that is all of the adjustment left in the stock eccentric bolts and I would have opted for -0.9
0 toe in front
0.8 positive caster
Yea this typa alignment is a must when upgrading your suspension.
How do you like the poly bushings though? I'm about the begin my own suspension overhaul and am worried the poly bushings will be too stiff.
As far as the ride you can only really notice when going around a turn at higher speeds also the turning is much sharper and accurate over all I am very pleased with this overhaul and I forgot to mention that I also have bg aluminum steering rack bushings but they have been installed for months.
TOPENDMS
Suspension and Brakes
09-24-18 08:48 PM
Ahheck01
02-12-15 07:00 PM
