some good info on brakes upgrade (spec)
Rotora Stage 1 brake upgrade all four corners. Fits OEM wheels, even 16'". Total cost is around $700. Note the stock calipers are used in this setup, this is not a BBK.
1. Rotora slotted OEM replacement rotors
2. Rotora stainless steel brake lines
3. Rotora ceramic brake pads.
Weight of the Rotora rotors only, measured on a postal scale. Weights are per rotor.
Front: 20.4lbs (9.25kg)
Rear: 12.8lbs (5.81kg)
My OEM rotors (2000 GS 400) had ~64,000 miles on them and weighed:
OEM front rotor: 19.9lbs
OEM rear rotor: 12.8lbs
