SAGE 18mm front RCA...installed.
Master Thread Closer!!
Some of you know I had 18mm front RCAs made for me since last year. The first set didn't fit properly...I had them re-designed and they fit, but I never installed them until recently because I was couldn't find the proper 12.9 grade bolt w the correct length. I recently had some longer bolts professional cut for me....and after install, took some pics....clearance is about 3 mm between the LS400 caliper and the outer tie rod castle nut/bolt tip when I turn the wheel to the left and right.
Im on airrunners, so I really didn't need the 30mm front RCA drop...just needed the 18mm RCAs to bump up the LS400 calipers.
Pete
Pete
Damn you Pete!!! I want those ones Wanna swap my 30mm ones for 18mm? I haven't installed them yet nad I'll cover shipping both ways I don't feel like grinding out the prototypes LOL I think the only way I can use your 18mm prototypes is if I grind through the center part all the way to clear the ball joint
Good news..I got word today that SAGE 18mm will be available in early Jan 2012...at a very good intro price.
These are made specifically to clear the LS400 BBK...and drops your 2GS by 18mm.
If you want a bigger drop...the 30mm and 40mm front RCA are available too.
Pete
Pete
