Sway Bar Bushing replacement
Its about that time I replace both front and rear swap bar bushing. Looking over the forum I see many people like the TRD and the energy.
Can someone provide me with the diameters for both the front and rear bars. From a google search it seems to be FRONT-28.5 REAR 14mm
Part numbers would be great for the TRD!
Merkur Fanatic
The front is 28.5 and the rear is 13.2. As for the TRD parts, I know they make bushings for their sway bar, not sure about the stock units.
Daizen makes a set of Poly bushings that should do the trick though.
Yes I actually found some on amazon prime for 12.00 for the set. I hope I got the correct rear ones though. I thought it said 14mm when I ordered for the rear. Did I get the wrong one??
This is from the Prothane website....
Lexus
SWAY BAR BUSHINGS, FRONT & REAR
(GS 300, 400, 430)
93-97 Front Sway Bar Bushing Kit, 30mm Bar 18-1128-BL
93-97 Rear Sway Bar Bushing Kit, 23mm Bar 18-1129-BL
98-05 Front Sway Bar Bushing Kit, 28.5mm Bar 18-1123-BL
98-05 Rear Sway Bar Bushing Kit, 14mm Bar 18-1124-BL
Lexus
(GS 300, 400, 430)
PHML
Suspension and Brakes
129
08-02-18 09:29 AM
