Please Help the noob, DAIZEN
Hello my fellow CL members. I was wondering where and how to buy DAIZEN bushings. I have read a lot of threads, from DIY DAIZEN bushings to those saying that you can't get products from TM Engineering (dealer that i considered first). I tried contacting the other two, no luck. Please, help me find places where I can buy DAIZEN bushings (I need the control arm bushing set). Thanks a lot ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
ps are there any alternatives to those DAIZEN bushings?
Upgrade to TRD sways. They come with sway bar bushings. Then contact Sewell for lower control arm/caster/trailing arm bushings. They seem to be the ones that people change out the most. When you do that, you might as well change your lower ball joints at the same time.
if this was really true, you should have seen the threads that said you CAN still get stuff from todd at @ tm but he's really slow....
https://www.clublexus.com/forums/sit...cl-vendor.html
if your JUST looking for the castor arm bushing you can get them from 3 places (2 atm)
sewell (depending on what year your car is the bushings will be different 98-00 use a different bushing than the 2001+ models)
https://www.clublexus.com/forums/sus...to-tm-eng.html
and carson carrys them
http://www.l-tunedparts.com/product/?id=3297
another vendor on here named figs is working on some that should be out soon (i repeat they arent ready for the gs yet but will be soon)
https://www.clublexus.com/forums/clu...from-figs.html
aarondds
Suspension and Brakes
10-06-10 03:47 AM
