Do coilovers dramatically camber your car?
Old 12-30-11, 04:14 PM
melski415
melski415's Avatar
Default Do coilovers dramatically camber your car?
Im getting coilovers next week. Will I camber a lot when lowered 2-3"? My ride is lowered by 1.5". Would I be better off just buying rca's instead of coilovers?
Old 01-26-12, 08:18 PM
jriggs
jriggs's Avatar
I'm 3 inches lower than stock and on spec using the factory adjustments. A good shop is all I needed for a proper alignment.
Old 01-26-12, 08:44 PM
AKS14
AKS14's Avatar
lowering your car will naturally cause it to camber in a bit..
I lowered my car on BC 'extreme drops' and right out of the box I had no wheel gap with 19s and a 35 series sidewall. With that being said, my camber was around -4 degrees all the way around, and on stock bolts I couldnt dial much if any out.
I installed SPC camber bolts in the rear as well as FIGS toe arms, and then took it to get aligned, the front ended up setting in at around -3.5 degrees, the rear is -1.5.
I would like to get the front dialed out a bit more to around -1.75 but the stock bolts just wont do it.
Old 01-27-12, 10:56 AM
GSteg
GSteg's Avatar
Camber will be there whether you lower the car on coils or springs. Dont be fooled to think you wont have camber wear with a 3" drop. Toe adjustment wont do magic but it can help preserve your tire life.
Danny365N
Suspension and Brakes
10-22-15 02:02 AM
snaggle
13
11-28-12 07:00 PM
verals05
IS F (2008-2014)
16
01-03-10 10:58 PM
1.5jzsupra
09-29-09 04:07 PM
NCDUB
03-24-09 02:40 PM
Quick Reply: Do coilovers dramatically camber your car?
