How can I adjust this / \???
Old 01-02-12, 03:58 PM
VIS250P
VIS250P's Avatar
Default How can I adjust this / \???
Im sooo confuse.. I need to buy parts really bad.. SHould I get Megan Upper camber and Traction arm? Does they make them like / \.. Let me know
Old 01-02-12, 04:01 PM
LamTheSham
LamTheSham's Avatar
For your tires? That's called negative camber.
Just get a rear Megans camber kit and set it to the negatives.
I believe SPC recently made a front camber kit for the 2IS also...not 100% sure though.
Old 01-02-12, 04:06 PM
VIS250P
VIS250P's Avatar
That a quick answer.... I forgot to mention to add camber kit on the title... Yeah I will get camber kit... Im too confuse because Megan sell 3 parts in the rear... They have two camber kit?? I mean if I get upper and that mean camber kit right.. What is lower part???
Old 01-02-12, 04:10 PM
steezy
steezy's Avatar
You only need the upper camber arms, one outta the three. You can correct your toe when you go alignment. The lower part? Are you talking about the lower control arm? You can go more negative if you have both I believe
Old 01-02-12, 04:15 PM
VIS250P
VIS250P's Avatar
U got the point.. Ok If I get the upper camber arm and willing to adjust to / \ and do the toe correct when I go do alignment.. What about other parts? What is Traction ARM do? And is that bottom part is camber or adjust caster or adjust toe????
Old 01-02-12, 04:24 PM
steezy
steezy's Avatar
"These Traction rods also allow for fine-tuned adjustments to the rear suspension geometry. By changing the length of the traction rod you change the position and pitch of which the suspension rotates upon and you change the amount of "Anti-Squat" of the rear. Although the adjustment is minimal, it can change the behavior or the vehicle during weight transfer." - Megan Racing
I believe the lower control arm only does camber
Old 01-02-12, 04:41 PM
VIS250P
VIS250P's Avatar
I spoke to the guy work at the shop, he told me the traction rods help adjust the toe correct but we have stock toe.. I was very confuse.. IF I get upper camber, Im not really sure if they can go more // \\.. I wish I have one simple answer
Old 01-02-12, 04:58 PM
steezy
steezy's Avatar
How negative are you planning to go? You can adjust the camber arm up to 1.5"
Old 01-02-12, 05:06 PM
VIS250P
VIS250P's Avatar
Boy, Im doing the research about the camber in this forum and made me
Old 01-02-12, 06:01 PM
VIS250P
VIS250P's Avatar
Well tomorrow Im gonna go work and wanna see my buddy IS300 rear lower control arm.. Im gonna measure between both IS300 and ISX50 lower control arm to see if they are same length.. Wish me luck
Old 01-02-12, 08:52 PM
JDKane527
JDKane527's Avatar
You should measure shock and sway mounting holes as well.
If it is swappable, it doesn't make sense why the 1IS mega arms from figs are like, half the price compared to 2IS.
Old 01-02-12, 08:56 PM
VIS250P
VIS250P's Avatar
YEah I want to do customize myself on the LCA and let see what happen
Old 01-05-12, 10:24 AM
joedad
joedad's Avatar
Default adjustment
Check FIGSENGINEERING, they have a rear LOWER camber arm and are coming out with an UPPER front camber/caster arm soon I hope. Click on the vender site at the top of this page and scroll down to FIGS
Old 01-05-12, 11:11 AM
VIS250P
VIS250P's Avatar
I check out this site and It cost about $600 buck
c-low
c-low's Avatar
i got megan camber arms rear and spc adjustable ball joints for the front
http://www.flickr.com/photos/32734554@N05/6091313251/http://www.flickr.com/photos/32734554@N05/6091313251/ by http://www.flickr.com/people/32734554@N05/, on Flickr
Quick Reply: How can I adjust this / \???
