GI: Poly bushings
Hi guys, gauging interest in a poly bushing applications geared towards the JZZ30.
Currently we can provide the following, just wondering how much interest there is and I will get them coming.
Front LCA (both eccentric and non eccentric)
Front UCA (centered only)
Front LCA rear both late model and early model 51.1mm/49.5mm
Front steering rack 47mm and 50mm diameters
Rear toe link
Rear Traction link subframe and spindle side
Rear upper Control arm
Rear LCA shock mount if same as GS300
Rear LCA inner mount if same as GS300 JSZ147
Rear subframe
Rear diff pinion mount
Sway bushings to chassis
49mm height front sway bar bushing
21,22,23,24,27,28,30,32mm available
44mm height front sway bar bushing
Bar diameter 24,27,30mm available
Rear Sway
42mm height rear sway bar bushing
24,25,26,27,28,29,30,32mm available
Rear Crossmember restraint washers, to tighted the cross member mount.
Reply with items in bold or just let us know, thanks, Mike
Rear toe link
Rear subframe
Rear Sway
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
We will be adding SC applications this year and already have a toe link that will works as it works on the Gen1 GS. There are a lot of common busings between the JZS147 and the SC.
Sorry for the scare. I had to clone most of two posts in two different forums
Mike
__________________
This was the info I was waiting for. More likely alot of people would be asking for these suspension parts;
http://eaurouge.jp/parts/
http://www.ikeya-f.co.jp/en/index.html
definitely be interested in any poly bushing for 99 model SC, as TM has horrible customer service.
also just liked yall on FB hope to see more from yall for the SC
