Need Rear Suspension Help PLZ!
I recently lowered my GS3 2 inches using Megan Springs. Since then my car has eaten through a brand new set of Hankook V12's in the rear. I havent had much luck with alignments and i need to correct the problem before i purchase another set of rear tires.
So my question is this, Can i fix my rear camber issues with a Megan Rear Toe control Arms for the IS300?
I havent seen a lot of info on this site about it. I talked to a rep from Megan and he said that he "heard" that it was possible. I am wondering if there is anyone on this site that can confirm this. Was the installation process easy? Did you have to make any adjustments in order for it to work? Did it just bolt on? and lastly, did it correct your camber problems????
Thanks for your help.
UPDATE!!!!!
FIGS is creating my arms as we speak. They will be shipped out early next week. So if i have time before my vacation i will put them on an update this thread. For now here's some pics of my rear tire....
Do you guys think i can get a couple more months out of this tire or should i replace it NOW!?
UPDATE!!!!!
Those are toe arms. They correct toe angle, which is what's probably causing you to eat tires given that you're only Megan springs. The ones from the IS300 will fit, but there will be some rubbing going on. I had the same toe arms on my car, but sold it to get some FIGS arms. Less bulky, and nicer rod ends.
did you have the car aligned after the spring install? 2" is not that much, it should be able to get into spec. except for the camber, it will most likely be out by 1-2 10ths of an inch. very small.
x2![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
i went with the rcas ( it was before i really knew about figs ( but i got a hell of a deal on them))
i was on tanabe df'swith the sage rear rca and was in all oem spec's toe, camber....and on 20x10's with 275/35 tires, just needed a fender shave. the df's made it -2 degrees but with the rca it brought it back into spec. i am now on megan lp's at nearly the same hight (tucking 1/2"-3/4" tire) and am .02 degree out of oem toe in the rear, hence why i am looking to get the figs links later.
true statement
you wont be sorry, and please update us
true statement
its only been 2.5 days since he said he was gonna order them....u think he ordered them,got them, and installed them that quickly?
he said he will update man just give him a second to do so, i would be surprised if he even had them yet.....that's assuming he already ordered them too
Ok here's a brief update, I have ordered my toe arms from FIGS and he stated that he would have them to me by 1-27-12
thanks for looking out Sakataj
