I need help ASAP BCR Coilovers Uneven drop
Old 01-19-12, 10:38 AM
LamTheSham
LamTheSham's Avatar
Wait what! I moved the bottom ring and adjusted the top collar. Is that how it's done? :O
Old 01-20-12, 05:51 PM
Fernanhaya
Fernanhaya's Avatar
I got confused too. I Loose the bottom ring and turn the 2 in the top at the same time that way i dont change my preload. I think im doing it right.
Old 01-20-12, 05:53 PM
Fernanhaya
Fernanhaya's Avatar
Originally Posted by CircuitMS
There is no issue with you adjusting one side more than the other if done properly.
Just adjust the height to where you need it at the lower collar and you should be fine
Any Ideas on what could cause that. Cause IMO i think an inch is way too much difference.
Old 01-28-12, 08:59 PM
CCJ22
CCJ22's Avatar
It's how our cars are. Nothing is wrong with your coils
Old 01-28-12, 10:38 PM
LamTheSham
LamTheSham's Avatar
Yeah. I was playing around with my rear coils and one side always sits differently regardless. I finally got it close enough and gave up. :P
Old 01-28-12, 10:45 PM
Shervin350
Shervin350's Avatar
is it a AWD?
Old 02-27-12, 09:42 AM
bduboulay
bduboulay's Avatar
Default Preload
I was messing aroun with my preload... Where should the preload sit? Do I just put it tight to the spring and that should reset them?
Old 02-28-12, 03:15 AM
LexStylez
LexStylez's Avatar
^^ This video should be useful
Old 02-28-12, 01:44 PM
bduboulay
bduboulay's Avatar
I installed my coilovers and there is clunking noise coming from the suspension. Anyone know what this could be?
Old 03-05-12, 08:19 PM
IS2FIFTY
IS2FIFTY's Avatar
any updates on this issue? lol I too just realized my back left is lower than my right but don't want to really mess with it if its not going to make a difference. I have a AWD if that makes a difference
Old 03-06-12, 07:17 AM
bduboulay
bduboulay's Avatar
You should fix that cause your car is going to ride uneven this is not good for breaking and accelerating. It throws the whole far off balance. Not to mention it doesn't look proper.
Old 03-06-12, 07:20 AM
LamTheSham
LamTheSham's Avatar
I dumped my **** even more yesterday. 1.5 finger gap from fender to rim in the front, 1/2 a finger from fender to rim in the rear. The rear right is always lower though. I adjusted it by making it three threads taller than the left side. So for me, in the rear, I have about 12 threads left before it is completely maxed out. I did 12 on the rear driver side, and 15 on the rear passenger side. That way, both sides sit even. :P
Old 03-06-12, 09:35 AM
bduboulay
bduboulay's Avatar
It took me a bit to get my car even at all 4 corners. You need to remember that if you lower the driver front it will raise the passenger rear and vise versa. I still dealing with some rubbing issues
Old 03-06-12, 02:10 PM
IS2FIFTY
IS2FIFTY's Avatar
my rear is just just off by a tiny bit, probably gonna lower it more tomorrow when I have some time
gtmassive
Suspension and Brakes
06-04-16 10:50 AM
someboy
13
07-16-11 07:30 AM
KangstaxD
03-23-11 06:27 PM
DennIS350
07-08-09 10:49 PM
Quick Reply: I need help ASAP BCR Coilovers Uneven drop
