What do you think this might be?
Old 01-16-12, 08:26 PM
birador
birador's Avatar
couldn't find the one from IS 2nd gen but this one might help.
https://www.clublexus.com/forums/sus...t-popping.html
Old 01-16-12, 09:42 PM
GiantsFan
GiantsFan's Avatar
Originally Posted by birador
my opinion is the brake pads,its what our brake component made,suspended of what they call so every time you make a first reverse and put brake on it will sound and if you put it drive and put brake it will sound again but as soon as you continue driving,it will disappear unless you make reverse and apply brake again,its not safety issue as per the tech that i talked to but its annoying and the best solution is to replace the pads and the kits,there's some thread already on this that they put some grease on the part that clunk but its only temporary..again this imo.
Ive heard the same thing - its because we have "floating calipers".
Old 01-16-12, 10:25 PM
J250
J250's Avatar
I am having the exact same issue as you.. And great description on the noise because I was debating to post this issue up in CL as well but couldn't find the right descriptions.. However, this happened to me ever since hitting a big pot hole.. Thought it was the CV joint.. but your description sounds identical.. Have you recently hit any major pot holes?
Old 01-16-12, 10:27 PM
Vroomin350
Vroomin350's Avatar
Damn dude I knew it, yes actually I have and I think I might have a slight bent rim as well, something is causing a vibration around 40mph but that's another topic. I am glad you understand what I mean, truthfully I thought my description sucked lol every one thinks its the pads, when was the last time you replaced yours?
Old 01-16-12, 10:43 PM
J250
J250's Avatar
lol, Well since you also hit a major pot hole, I have a feeling it's something way worst than just changing brake pads. The pot hole I hit during summer dented both my front and back wheel. I changed my brake pads 2 months after and the noise was still there..
However, since it's winter up here in Canada, I switched back to my stock 17's and to be honest, either I adapted to the popping noise or the noise is actually starting to disappear.
I did glance at the link birador provided and it might work because it does seem like similar issues.
BTW, the slight dent on your wheel is definitely one of the reason causing the vibration at 40mph.. I was going through the same issue after i dented mine...
Old 01-17-12, 02:28 AM
A_Grasso
A_Grasso's Avatar
Yeah bro, I'm like 90% sure it's the pads. The sound went away for me once I replaced the pads . Hopefully it will work for you as well!
Old 01-17-12, 09:16 AM
Stylnhonda
Stylnhonda's Avatar
I may have the same issue, kinda. I've noticed if I back into a parking spot, the brakes or the steering wheel or the brake pedel seem to make a odd pop noise at times. I don't think it's each time I reverse. I guess it could be and I just don't notice it all the time. I did not think much of it though. Mine only does it when I reverse and it's not to loud. Sounds almost like air.
My car's a 2011 with 4k miles and no mod's to the suspension/brakes/tires/wheels etc.
Old 01-19-12, 02:32 PM
Vroomin350
Vroomin350's Avatar
^^ thanks for chiming in guys, definitely this is more than just air, you can hear a metal noise pop. good news for you sir
muggy, did you ever get the wheels straightened back out ?
Old 01-23-12, 10:01 AM
Vroomin350
Vroomin350's Avatar
someone else experiencing the same problem over in the 2gs forums.. the following is a comment made by someone and the reason I post it is because it is a symptom I also have...
this is begining to become frustrating... i suffer from this too on my 2gs, but i only hear it when i back up in the morning and brake, after that i doesnt make that noise again till the next morning cold start. if someone can figure this out it would be so nice.
Old 01-23-12, 11:53 AM
B16da9
B16da9's Avatar
Johan it's your brake pads, my car does the same exact thing especially in the early A.M. I also think it's only an issue with 350 owners as my car did not start to do it until I did the 350 brake upgrade.
Old 01-23-12, 11:56 AM
Vroomin350
Vroomin350's Avatar
I am starting to think the same thing erick, most people said that but its crazy because the noise doesnt sound like it could come from anything in the pads... oh well, looks like new pads coming soon
Old 01-23-12, 12:52 PM
B16da9
B16da9's Avatar
I dont think it's the pads per say but more like the shims.
Old 01-27-12, 06:06 PM
NewLexus11
NewLexus11's Avatar
Sounds to me sort of like pad shift. I work at a lexus dealer and we get customers coming in alot with concerns about a popping noise when they first apply the brakes when in drive then reverse. If this is what the issue is it isn't anything that is serious as long as you can deal with the shifting noise.
Old 04-13-12, 10:23 AM
CCJ22
CCJ22's Avatar
What was the fix Yoan?
uncandid
10-01-12 07:18 PM
wth98sc
Performance & Maintenance
05-08-12 05:00 PM
rtDDS26
03-13-09 05:31 AM
KuyaPatz
05-11-06 06:21 PM
/Aerostar\
Suspension and Brakes
04-17-04 06:21 PM
Quick Reply: What do you think this might be?
