View Poll Results: Which one?
Lower Suspension brace
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
3.23%
Lower Chassis brace
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
25.81%
Both
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
22
70.97%
Voters: 31. You may not vote on this poll
Tom's rear lower suspension brace or rear lower chassis brace, or both?
The One
Originally Posted by chuckb
I know it's an old thread but does this Tom's brace bolt right up to my GS430? http://www.l-tunedparts.com/product/?id=444
Also, does TRD make an equivalent?
Originally Posted by Neo
I believe it will bolt up fine. As for TRD, no equivalent.
The Toms Lower Rear Chassis brace uses the GS' existing bolts. You might want to do the install when your gas level is low, since you will be taking out two bolts ( one on each side ) that support the gas tank. You can also use a support ( jack, etc. ) to help assist when doing those two bolts. This is not a tough job - you should not have any problems. Good luck
Oh, and I vote 4) Both Toms LCB's - front and rear plus the 6 links!
