air bags from a lincoln navigator?
Hey all, anyone have info on whether airbags from a stock 2003 navigator will work on sc struts? Just curious because I have a set of stock SC struts and a set of struts with bags from a Navigator
lolz Sorry for the confusion. I meant to say, is it possible to change the springs on our stock coilovers to the bags from the Navigator? I'm already running some Stance GR+ coils just curious if this would work as another suspension setup.
Also if it's just the strut without the spring is that also called the shock?
Spring + strut = Coilover
Strut = shock?
Strut = shock?
Won't work haha. Shock diameter is 62mm as is the inner diameter of the airbag, but i don't have a spring perch that will correctly seal the bag. The perch from the other strut has a much smaller inner diameter and will not fit over the old strut. Oh well.
