Question About Brake Pads?
!!!!!!Watsup CL!!!!!
2008 IS250 38,000 miles
When do i need to change the brake pad? do i have to get the rotor change as well?
its make noise whenever i break does this mean its time to replace?
BTW what brand or where do i get LOW DUST PADS?
Thanks a lot
Thanks a lot
ok first of all is Brake Pad, second of all wrong place for this thread, 3rd i changed mine at 35k but than i got a 350 idk bout 250s but this the part number for the low dust pads cheapest place to get them is at carsontoyota
Dude search is your friend. I just posted something about squealing the other day. As far as changing your brakes. Most tire places check them free. For changing the rotors, its not necessary but at least get them resurfaced. Anything ceramic will have lower dust as far as brake pads go. Check Sewell Lexus. You can register as a Club Lexus member and get a discount. There shipping and customer service is great!
Know the difference between break and brake.
Also "where do I get those LOW DUST PAD?".... You mean pads... Unless of course you want one. In which you should have written: Where do I get a low dust pad?
Also no need to yell at us with your caps lock
To answer your questions. Get pads from sewell. No need to change rotors during a pad change less rotors require this but if you ask Kurtz rotors don't go bad less you drive like this guy below in the youtube video.
http://www.youtube.com/watch?v=unwujSVpZwA
As others have noted, change when the pad is about worn out. For some people that's 20,000 miles... for some people that'd 50,000 miles. Depends on how they drive. Min spec is 1 mm, so if it's down to that (or down to 2mm if you wanna be paranoid/proactive) then change it. If it's more, don't. Most places do free checks.
And yes, get the low dust pads.
sdpq
01-31-08 10:26 AM
