Suspension wear and tear
Quick question: if I were to install this strut bar on a stock car/stock suspension, wouldn't that cause more wear an tear on my suspension?*
My reason saying that is because I would be reducing body flex causing things to wear out quicker being that there is less leeway. Right or wrong?
Former Sponsor
They really don't do much so we are both disagreeing with you. Every car at stock height is prone to body roll, my 240sx specifically, but initially having a strut bar will do next to nothing. You should save the money for a nicer suspension, which will in turn reduce body roll.
STB on the Z30 chassis are pointless. The body roll that our stock cars exhibit is due to the heft of these tanks, If you are looking to lessen body roll, pick yourself up a quality adjustable suspension. I can't tell you what to buy as I don't know your performance goals. JE can point you in the right direction as his experience has been in the "performance" side of the industry for a few years.
Great info guys. Adjustable suspension meaning coilovers? Also, Im working on my NA-T setup right now but also trying to stiffen the suspension and reduce body roll. I planned to get TT LCA's in the near future as well but whats something that would benefit my car right now? sway bars?
Former Sponsor
So what benefit would front and rear sways have?
Strut tower bars tie the the strut towers together to reduce chassis flex, but unless you have addressed other areas of the suspension, ie sways, bushings, struts/springs, tires, the benefits would be minimal at best as the stock bushings/suspension will take up most of the cornering forces before the chassis will ever flex enough to warrant any chassis bracing.
Hope this helps
Thanks,
Rick
bigcory
02-28-08 12:37 PM
