Roca-Usa Lower Control Arm Bushings
#32
I got my no 2 bushes here.
http://eshop.supergt.com.hk/preview/...k&onsell=false
But I think they are no longer made. You can just buy the complete lower arms for the 2001 to 2005 GS and it will come with TRD type bushes fitted.
I got my no 1 bushes here.
http://www.rhdjapan.com/trd-front-lo...0-jzs161-17918
#34
How is the ROCA USA bushing running folks?
The ROCA USA is a sub-division of Megan racing here in California. It's in the after market in since 2001. Hell either way I rather spend couple hundred dollars on replacing those bushing instead of probably more then thousand $$$$. The two UCA alone is already $650 just for parts.
#35
http://www.trdparts.jp/english/list_aristo.html
although it DOES show the 48655-JS600 to be discontinued the 48655-JS610 seems to be a replacement and is still available
http://www.rhdjapan.com/trd-front-lo...61-zenki-17921
interesting,so they have a good assortment of bushings from TRD for our cars
http://www.rhdjapan.com/trd-front-up...0-jzs161-17923
http://www.rhdjapan.com/trd-rear-axl...0-jzs161-17922
http://www.rhdjapan.com/trd-rear-low...0-jzs161-17917
http://www.rhdjapan.com/trd-rear-sho...0-jzs161-17919
http://www.rhdjapan.com/trd-rear-sho...0-jzs161-17920
http://www.rhdjapan.com/trd-rear-upp...0-jzs161-17915
http://www.rhdjapan.com/trd-rear-upp...0-jzs161-17916
#36
That's great info Brian... I did not realize that TRD made all these replacement bushings. I wonder if they are OEM or stiffer, they say that these bushing are "a great item for any modified vehicle and for those looking to increase the handling characteristics of their vehicle. The mounts will better stabilize the suspension during spirited driving especially during braking, cornering and acceleration."
#37
Did my Roca swap today: https://www.clublexus.com/forums/7062204-post98.html
But the ride is incredible, it's like have that new car back. I'd be hardpressed to ever go back to poly bushings again, at least not Daizens.
#38
#39
Once I replaced the Daizens with the Roca bushings, ALL of that went away. I never expected that extra benefit. It's just solid and quiet.
I can't say how the Rocas compare to Daizens in hard or spirited driving, I don't drive my car that way. From my POV, the best performance oriented approach would be the Figs spherical bearing approach, it looks killer. But for me, I would not want to put up with the extra transmitted noise and "feel". I like the OEM feel .
#40
#42
Here is my DIY writeup on how to replace them, including the source: https://www.clublexus.com/forums/sus...placement.html
#43
Thanks to Brian's research, looks like you can get them here: http://www.rhdjapan.com/trd-rear-axl...0-jzs161-17922
#44
you can buy mine....they sitting in my center console. i paid $130 for them shipped and waited a month or so for them....im gonna try the TRD ones (plus a few extra TRD bushings while im at it)
so this should be a nice post from me (probably my best lately) but per their schematics #8 is missing...they dont even show a bushing for it! so kind of for myself as a quick reference, im gonna label these....or try to their schematics is cruddy so anyone feel free to correct me but this should help ALL of us
Front Upper Pillow Mounts
(#1 on their diagram)
Rear Shock Bushing
(if u gonna replace one of these replace BOTH these) one per side....although i would think once you put coilovers on you dont need these anymore or could even use them but i dunno its been a minute since i seen my rear coilovers off
(#2 on their diagram)
(#3 on their diagram)
LCA # 1
(#4 on their diagram)
Castor Arm Bushing or LCA # 2
(#5 on their diagram)
Rear Upper Control Arm (each side takes one of these)
(#6 on their diagram) inside of the upper control arm
(#7 on their diagram) outside of the upper control arm
Rear Axle Carrier Knuckle Bushings
(#9 on their diagram)
Rear Axle Carrier Bushings (for the lower part of the trac links)
(#10 on their diagram)
#45
i think u linked the wrong ones btw..... i think the ones he wants are these
