Roca-Usa Lower Control Arm Bushings
Old 03-08-12, 02:31 PM
  #46
lyonkster
lyonkster's Avatar
Originally Posted by sakataj
i think u linked the wrong ones btw..... i think the ones he wants are these
http://www.rhdjapan.com/trd-rear-low...0-jzs161-17917
Yup, good catch!
Old 03-29-12, 12:46 PM
  #47
justablkv8
justablkv8's Avatar
Anyone order these?
http://www.rhdjapan.com/trd-front-lo...61-zenki-17921
Would like to know because my caster is out.
Old 06-25-12, 11:44 PM
  #48
JeffTsai
JeffTsai's Avatar
Keep in mind if your car is a 98-00 or Zenki then the TRD caster bushings will work. The 01-05 are the Kouki and will not work with the TRD caster bushings. They do not make a kouki caster bushing. The front lower control are bushings are the same for both models.
I just tore one of my Daizen bushigns today, so I'm going to order new TRD ones instead.
Are the ROCA caster bushings for the 98-00 or 01-05 GS?
Old 06-26-12, 05:25 AM
  #49
BiGEZ
BiGEZ's Avatar
Roca recently changed their listing of the bushings. They had P/N RC-666092 listed for the 98-05 GS300/400
but now they have the same P/N listed only for the 89-00 GS300. I talked to Paul at Roca and he said they are trying to verify that part fits the 01-05 GS300.
For you guys that installed this part in your 01-05 GS are you having any issues with them.?
Old 06-26-12, 06:23 AM
  #50
lyonkster
lyonkster's Avatar
The ones I bought were listed as being for "98-05 GS300/400/430", and they fit perfectly into my '01 GS430, no issues.
Old 06-26-12, 09:58 AM
  #51
repugnante
repugnante's Avatar
I bit the bullet and went with these. Pressed in just fine but one noticeable issue...the bushing ring doesn't appear to go all the way to the end even though from the top, it looks pressed in all the way. Are the Roca's shorter??
Old 07-16-12, 11:20 AM
  #52
bee0818
bee0818's Avatar
I thought I read that Sewell sold the 03-05 castor arms that are thicker than the 98-02 arms and came with the TRD bushings. Is this wrong?
Old 07-16-12, 11:53 AM
  #53
repugnante
repugnante's Avatar
They're not thicker. The 03-05 has the TRD bushings pressed however, it's not poly, its the same hard rubber that came with the car. 98-00 had the smaller arms, althought certain 2000 models that were built late had the larger arm. I think its the 00 model that was manufactured after June of 1999. I have a 2000 and the larger armwas already on the car. 00-02 had the larger arm but didn't have the TRD bushing pressed into them
Old 08-21-12, 03:47 PM
  #54
BayAreaLex
BayAreaLex's Avatar
Maybe I missed it, but can you confirm the part# and the source you get your ROCAs from?
Old 09-11-12, 03:54 PM
  #55
B4TM4N
B4TM4N's Avatar
Hey there, did you get an update on this situation? I have a 1999 and don't know whether I should order the part number you listed.
Old 11-12-12, 12:01 AM
  #56
Janitor4
Janitor4's Avatar
Smile TRD caster arm bushing confusion
Hello everyone, thank you all for the TRD bushings info firs of all. I have a question and hope you guys van help me resolve the issue!
I have been emailing with RHDjapan regarding the caster arm bushing set Part Num: 48655-JS610. Since the almost same item Part Num: 48655-JS600 has been discontinued and no longer available I ordered the Part Num: 48655-JS610, assuming it will fit Aristo JZS160 .I have 2004 GS300 and based on my VIN it is 2JZ-GE and it should be Kouki as the refer to it.
RHDjapan said they will not fit my car since based on this : http://www.trdparts.jp/english/list_aristo.html
they are for a previous year model.
I wand to ask if anyone has any idea if those bushes will fit a 2004 GS300 or a Kouki or will the caster arms be too DEEP for the outside metal cover of the bushing? ANd if the DONT fit do i need the Part Num: 48655-JS600. Thank you and i apologize if such question has been discussed before but i couldn't realize it.
Old 12-01-12, 09:28 AM
  #57
jzs16risto
jzs16risto's Avatar
Originally Posted by shurian
Came across Roca-Usa Lower Control Arm bushings on Ebay for both lower arms #1 and #2 is anybody have installed them? Can provide feedback for quality?
Link:
http://www.ebay.com/itm/ROCA-GS300-J...item27c2f9d560
Posted from ClubLexus.com App for Android
Old 12-10-12, 09:09 PM
  #58
Tinker
Tinker's Avatar
Yeah, a little silly considering the bushings are the same for both sides. Sort of like selling "right" and "left" spark plugs .
I am going to order the bushings by Roca off Ebay. I was wondering whether I should buy them as listed for left and right side, or just get two of the same part number, since both sides are the same. What do you think?
Old 12-11-12, 04:52 AM
  #59
BiGEZ
BiGEZ's Avatar
Same part for L&R sides, no difference.
Old 12-12-12, 04:23 PM
  #60
Tinker
Tinker's Avatar
Thanks for the reply! In the meanwhile I went ahead and ordered each separately. I figured that way I could get more trade history with ebay, if that's worth anything. Now I expect to recieve two boxes that are the same, funy.
Quick Reply: Roca-Usa Lower Control Arm Bushings
