Steering rack bushings
I bought the Battle version aluminum rack bushings and braided power steering hose from driftmotion. I have been very happy with both of them other than a bit of noise/vibration that transmits through the steering wheel when turning, but that is to be expected with solid bushings.
The whine is probably coming from a lack of sufficient ps fluid or air in the system. Check the ps dipstick to make sure theres enough.
People dont sell bushings because people will buy them and leave them in forever. If you want solid, go for battle version's aluminum, though because theyre solid, they transfer every vibration from the road to your hands
If you want better than stock, run r2 bushings, do search on here. Actually, a lot of this info couldve been had with a search.
where exactly did you get the daizens from? unless tm engineering popped back into business while I wasn't paying attention, I'm not sure you`ll be getting much, reasoning behind me not mentioning daizen.
akafixture
Suspension and Brakes
11-10-14 08:05 AM
