New steering column
Hey guys been having a problem with my steering wheel, whenever I take a turn the steering wheel doesn't straighten out, also whenever I turn to the left theres a creaking noise like a rusty door that needs to be oiled. I already got a alignment but didn't fix it. The mechanic said it was $900 - 1k since the whole steering column needs to be replaced. Do you think that is too much?
Could just be the steering rack bushings. Mine were shot and anytime I would take a turn, the steering wheel would be stuck in the 10 o'clock position or the 3 o'clock position, and if I would turn the wheel with the engine off, I could hear the steering rack sliding in the bushings, making an odd noise. You can check your rack by having a buddy sit in the car and turn the steering wheel while you are looking at the steering rack, if you can see it physically move back and forth, you just need new steering rack bushings. Hopefully that is the problem, as it is a super easy and cheap fix.
Thanks,
Rick
Thanks,
Rick
MIGS
Performance & Maintenance
12
11-14-10 06:25 PM
SC400TT
Suspension and Brakes
13
01-27-05 09:32 AM
