Ceased Calipers
Old 02-14-12, 06:52 PM
BernieIS
BernieIS's Avatar
Default Ceased Calipers
Has anyone had their rear IS350 calipers slide pins cease up? I have a 2008 CPO IS350 that was purchased in July 2011 and the rear caliper slide pins have ceased up. To replace them it is $600.00. Is this common? Does the caliper, slide pin, and bracket come apart? I am trying to powder coat the calipers and can get them apart. Some advice would be greatly appreciated.
Old 02-16-12, 10:55 AM
White350
White350's Avatar
My car one of the rear pins were seized, I had to cut the pin, replace the caliper and order a new pin for the bracket
unless you have an oxy/acetylene torch you wont be able to get the pin out
Old 02-21-12, 12:09 PM
Cesar1047
Cesar1047's Avatar
checkout post #61 on "diy rear brake pad change-IS250".
Old 02-21-12, 12:24 PM
PaPaHoFF
PaPaHoFF's Avatar
ive had a rear passenger seize before overheated and cracked my rotor and melted the pads x2
maimou
GX - 1st Gen (2003-2009)
03-31-17 12:12 PM
Soledad
Suspension and Brakes
03-08-16 01:47 PM
iGS430
01-19-15 04:46 PM
EXL124
15
05-20-13 02:46 PM
Quick Reply: Ceased Calipers
