08 350: rotors or brake pads?
Hello CL fam,
I have an 08 is 350 with 50k miles. I got the car new, had the high performance brake pads that showered dust all over the wheels, got Lexus to replace them for the standard brake pads with lesser dust at around 20k miles. I have started to notice some difference in braking, specifically in these last 7-8k miles that I've driven. It feels as if the brakes don't catch as fast. There is also some minor vibration that I feel in the brake pedal and secondarily in the steering wheel when I brake to a stop at from higher speeds (50-60 mph).
My tires are in good shape and so is my alignment. I'm pretty sure it's the brakes. My question is, do I need new pads? New rotors? Is there any such thing as having you're rotors reshaven?
As always, your input and insight is greatly appreciated.
The low dust pads stop the car exactly as short as the high dust ones, because pads don't change braking distance.... but they do feel different... the low dust pads are less grabby (which many like, since it gives them a wider range in which to modulate braking force)
Vibration when braking is usually caused by even pad transfer... if this is recent you might be able to fix it with rebedding the pads... if that doesn't do it hitting the rotors with a garnet pad might work.
Otherwise you might be bad off enough to need to replace the rotors (resurfacing is an option if they're really bad and don't respond otherwise, but results can be...not great... from that depending how the shop does it, and it's often not much cheaper than new rotors)
A lot more info on the real cause of the issue, what to do about it, and how to avoid it in the future here:
http://www.stoptech.com/technical-su...nd-other-myths
Hey gville, thanks for the input...any good website recommensations to get thr pads and rotors for the price you listed? How much is installation usually- thinking abt taking it to toyota for the rotors
At least? I can prolly do the pads myself but if I am getting my rotors
Changed....might as well get my pads done too?
Thanks
Thanks
^Bro, if you can operate a socket wrench, pliers, a T-clamp, and a jack...you can do pads/rotors on a 350. Very simple job with the caliper design on these cars.
For pads, a lot of people like OEM. For OEM parts, I'd recommend Sewell Lexus. Club Lexus members get discounts through their website. For aftermarket pads, you have various options. I have StopTech Streets right now, and dislike them. I like to have a better initial bite with my braking, and these are more like OE dustless pads I think. I wish I could have gotten Axxis/PBR Ultimate ceramic pads...but they were sold out nationwide and on backorder when I needed pads.
For rotors, blanks are best. OEM/aftermarket...it don't matter. I love my PowerSlot rotors though; they engineer the internal fins inside the rotor to better cool the rotor core than OE-type rotors and I love the way the slots look too.
Do the install yourself and save the $100-200 you would pay someone else to do it. With the money saved, you can buy more mods/tools!
I just did the brakes on my car and it took my about an hour but I also flushed the fluid so shouldnt take more than 30-40 minutes to do pads and rotors. I went with Centric brakes cause I get them at wholesale from Tire Rack and they make most of the OEM brakes on the market anyways. If you were closer I could help you
....For pads, a lot of people like OEM. For OEM parts, I'd recommend Sewell Lexus. Club Lexus members get discounts through their website. For aftermarket pads, you have various options. I have StopTech Streets right now, and dislike them. I like to have a better initial bite with my braking, and these are more like OE dustless pads I think. I wish I could have gotten Axxis/PBR Ultimate ceramic pads...but they were sold out nationwide and on backorder when I needed pads.
I've also included my screenshots of my RockAuto shopping cart (which I can't get to work right so I'm not ordering from them) and my Sewell shopping cart of OEM items for reference. a $400ish savings for the Centric route. Not bad.
smokyis350
Suspension and Brakes
03-16-10 03:51 AM
