Painting Brake Caliper
Old 10-22-02, 08:40 PM
Lexdub99
Lexdub99's Avatar
Default Painting Break Caliper
I am having a problem with getting the high heat engine paint i bough to stick to my brake caliper in certain spots does anyone know what i am doing wrong or if i should get a different kind of paint. I followed exactly what bannags said and im still having difficulties
Old 10-22-02, 11:38 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: Painting Break Caliper
that's weird, did you use the brake spray cleaner to clean your caliper first? i did that and then put on some high temp engine enamel and it's staying there pretty good
Old 10-23-02, 10:03 AM
KayGee
KayGee's Avatar
I used VHT caliper paint and it seems to be holding up pretty good.
Old 10-23-02, 12:11 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,241 Likes on 1,360 Posts
Kaygee - where did you get the paint you used?
Old 10-23-02, 01:47 PM
KayGee
KayGee's Avatar
http://www.newedgeperformance.com/vhtbrakcaldr.html
New Edge Performance also sells Ford Escort/Focus performance parts. That sounds like an oxymoron doesn't it.
Old 10-23-02, 03:06 PM
JYOO
Guest
Posts: n/a
I got that same can of paint for 6.99 at ACTION AUTO PARTS!
Worked OK.
Old 10-23-02, 06:53 PM
DrewGS4
DrewGS4's Avatar
I used VHT as well, and its holding nicely so far
Old 10-24-02, 12:45 PM
MrSypher
MrSypher's Avatar
I used G2 caliper paint and IMO it's the best... Nothing to mask or cover.... I used VHT caliper paint in my enigine bay..
Old 10-24-02, 10:06 PM
LS4fun
LS4fun's Avatar
I used Foliatec which is I think easier to apply since it is applied with a brush and not spray. This way you dont have to go crazy with masking tape and the overspray. It does come with a cleaner that you need to apply to the calipers to ensure good adhesion. I bought it on the web.
I also recommend that you dont mix the whole paint / lacquer contents together. Foliatec provides you enough to do a couple of cars so save it for future applications / touchups.
someboy
12-13-10 08:29 AM
Vadim
Suspension and Brakes
10-07-07 05:32 AM
recco1
27
05-27-04 06:40 PM
VEGASRX330
RX - 1st Gen (1999-2003)
05-27-04 03:28 PM
DELTEC1
12-23-03 05:41 AM
Quick Reply: Painting Brake Caliper
