Help! Where are the Trac components?
10th Gear
I rebuilt the brakes on my 97 sc4 and now need to bleed the system. The problem is I can't find the accumulator or actuator for the Trac system. I have a button on the console for Trac, the light on the IP goes on and off, I looked in the engine compartment where the manual says the system should be, and it's not there. According to the manual, the accumulator should be next to the master cylinder in the left rear of the engine compartment. Not there. And the actuator should be in the right rear next to the ABS system. Not there. I see a bleed valve on the aluminum ABS system actuator, but that's it. I'm totally stumped.
Thanks for the help.
Eric
Eric
I'm resurecting this thread because i have the same problem!
Does anyone have a pic of a 97 that shows the TRAC accumulator location? There is nothing under my master cylinder, and yes, I do have trac control. The ABS controler is plainly visible on the passenger side , but the TRAC? I'm trying to bleed the system but where is it? Is there something odd about the 97s?
Any help would be appreciated!
Regards,
M.R.
Regards,
M.R.
My 97 is the same exact way. I am unsure of the proper procedure to bleed the brakes now. I opened that bleeder on the ABS system actuator and started the car and the pump did not energize making fluid come out. I jacked up the rear of the car and let the wheels spin in drive and still nothing.
