Well finally got arround to it, taking a closer look the bushing did not look bad. It turned out to be loose bolts. Tighten them and the noise is gone, embarrasing. Now I'm stuck with a new set of bushings. Ahhhhhhhhh!!!!
It makes noise on my side of the car especially when I make left turns so it's best to check to see if they bolts are tight and if not then it's the bushings right
